How to do a screen recording to show a problem
Modified on Wed, 17 Jan, 2018 at 1:21 PM
Many times, the best way to report a problem is simply recording the screen while it occurs.
We use and suggest a tiny app called RecordIt. It is free, multi-platform and lets you record the screen as a GIF. The file is saved on cloud and you just share its link. Works very well to register problems with applications.
Its site: http://recordit.co
