FontLab Studio 5.1.4 and earlier cannot launch on High Sierra.
If Fontlab 5 is installed fresh after the High Sierra upgrade (or if the license file is removed), you will see this error message:
“Error initializing license system. Bad or missing or expired RLM license (-130)...”
The solution is to install Fontlab Studio 5.1.6 (a free update for 5.0/5.1.x)
http://www.fontlab.com/downloads/Installers/FLS5MacFull.dmg
Note
People using axis-based (Multiple Master) type design in FontLab Studio 5 should not upgrade at this time.
