Install Python 3
macOS
- In Finder, to /Applications/Utilities/
- Double-click Terminal.app
- In Terminal, paste this and press Enter:
[ ! -x "$(which brew)" ] && /usr/bin/ruby -e "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/master/install)"; brew install python
- Wait until the installation completes and stay in the Terminal.
Windows 10
- In Windows 10, go to https://www.microsoft.com/store/productId/9MSSZTT1N39L
- Click Get, then Open Microsoft Store
- When Microsoft Store opens, click Get, then Install
- Once the installation is complete, close Microsoft Store, right-click the Start menu and choose Run. In the box, type
cmdand click OK to open the Command Prompt.
Older Windows
- Go to https://www.python.org/downloads/windows/
- If your system is 64-bit, click Download Windows x86-64 executable installer for the latest Python 3 version
- If your system is 32-bit, click Download Windows x86 executable installer for the latest Python 3 version
- Double-click the downloaded file and install Python 3
- When the installation is complete, right-click the Start menu and choose Run. In the box, type
Install fontmake
In Terminal or Command Prompt type this and press Enter, then wait until the installation completes:
python3 -m pip install --user --upgrade fontmake
Export DesignSpace+UFO
When you have a FontLab font with multiple masters:
- Choose File > Export Font As...
- Choose the DesignSpace + UFO profile
- In Destination, choose a destination folder
- Click Export
Convert DesignSpace+UFO to final fonts with fontmake
In Terminal or Command Prompt type the following command and press Enter. DESIGNSPACE_PATH refers to the path (location) of the .designSpace file that you exported from FontLab. To get the actual path, instead of typing DESIGNSPACE_PATH, drag your .designSpace file from Finder to Terminal or from File Explorer to Command Prompt.
To export your predefined instances as static TTF and OTF fonts:
python3 -m fontmake -i -m DESIGNSPACE_PATH
To export your font as a Variable TT font:
python3 -m fontmake -o variable -m DESIGNSPACE_PATH
To see more export options:
python3 -m fontmake --help
